I`ve done it on my 1968 Valiant 408 smallblock. Ran 9.844 sec @ 134.4 mph and steering was absolutely fine ( kept in it after the gate, got up to approx 150 mph to give the steering a real good test )
Rack is a shortened left hand drive 1960`s Morris Minor rack and pinion, using a double Borgsson joint ( Summit racing ) on the steering colomn. Still using a standard k frame and standard engine mounts. Standard torsion bars remain in place with custom made bracet supported from both chassis rails sitting behind back of Milodon sump.
Ball joints removed and new drag links made
With some basic careful fabrication you should be able to make any manual rack fit
Good luck !!
