Im using a 97 jeep grand cherokee 5.2-5.9 v8 radiator, but im running a 5.7 hemi. I chose this radiator because i got it new on ebay cheaper then a custom radiator, the inlets and out lets match the hemi's, and if it ever went out i could easily replace it at an autoparts store. I have a 64 dart and welded in a 66 radiator support to give me more room for a opening (the 64s was too small). I also trimmed the flat flange area by the frame only a touch so that the 97 radiator would fit nicely. Then I made some mounting brackets and welded then into place to support the radiator vertically. I then drilled holes in the lower radiator support so that the two plastic prongs on the bottom of the radiator would sit down in the lower radiator support. I still have to weld the lower support on, but its all coming together nicely. Im not sure if the 360s inlet and out lets on the pump will match up to the 97 jeep grand cherokee radiator, but if your interested in what i did, check out the thread in the restoration area on this site, its under "64 dodge dart 5.7 hemi install". I will be using an electric fan, but i may use the 97 cherokee shroud aswell and just have the electric fan inside the area where the motors fan would have turned.
Even if you cant use the 97 jeep radiator there might be other radiators you could do the same thing with. Just make sure you take lost of measurements first. Hope this helps.
