Radiator for 1968 Barracuda 440
Cold Case Aluminum Radiators
  1. kmabry
    kmabry FABO Gold Member FABO Gold Member
    33
    23
    Aug 25, 2018
    Arrington Tn
    Local Time:
    4:12 AM
    Was wanting to see what you offer for a 1968 Barracuda 440 4 speed its wanting to heat up in traffic.
    Any suggestions would be great!
    Thanks kenny
  2. famous bob
    famous bob mopar misfit FABO Gold Member
    16,642
    6408
    Aug 14, 2011
    okla
    Local Time:
    4:12 AM
    Following -----------
  3. 63spf
    63spf MOPAR 4 LIFE ! MOPAR OR NO CAR ! PLYMOUTH'S RULE ! FABO Gold Member
    2,140
    1576
    Mar 9, 2016
    Kona , Hawaii
    Local Time:
    11:12 PM
    Sad , Very very Sad. I would like some info on that also !
    • Like Like x 2
    • famous bob
      16,642
      6408
      Aug 14, 2011
      okla
      Local Time:
      4:12 AM
      Well I`ll kick it off, 440/505 , running a 28x19 crossflow w/ 2 rows of 1 1/4'' tubes , flow cooler water pump , 17''/6 blade mech clutch fan , w/ full shroud.
      Runs best about 190 and above, and runs mostly around that to 210.
      Am installing a little smaller water pump pulley that will turn the fan faster and
      pump more water.
      Have been on the edge of over heating when it`s late summer , but havent had to set in traffic very long.
      • Thanks! Thanks! x 2
      • jbc426
        jbc426 Well-Known Member
        1,811
        639
        May 30, 2007
        West Coast
        Local Time:
        2:12 AM
        I order my custom radiators from US Radiator. Especially with the smaller 22" opening. They have several different build options they can use depending on your specific application.
        As mentioned above, the radiator is just one link in the chain of good cooling. You will need a proper fan, thermal clutch, water pulley set-up and shroud to get the greatest cumulative cooling effect.
        • Thanks! Thanks! x 1
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          15,400
          4258
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          4:12 AM
          Wow, I can’t believe CCas hasn’t replied to their own thread. Kim
        • OnEbAd340
          OnEbAd340 Well-Known Member
          76
          22
          Mar 19, 2006
          RI
          Local Time:
          4:12 AM
          I bought their radiator for my 69 340 and couldn't be happier. Its one of the only aftermarket items on the car that actaully fit. I called them up and had it within 2 days.
        • famous bob
          16,642
          6408
          Aug 14, 2011
          okla
          Local Time:
          4:12 AM
          I havent opened up the cradle to expose the side tanks , either , may help a hair .
          And can go to an 18'' fan if need be .
