Radiator hoses
What radiator are you using?
Is it designed specifically for a BB.?
The reason I'm asking is 67 thru 69 had a 383 / 440 option and if the rad matches that years' requirement (inlet and outlet size and location) you should be able to order those stock hoses for your 70 application.
I have an aftermarket be cool radiator In my b body. Top drivers into my small block. I took a hanger and bent in shape of the hose. Took it to my buddy at Napa and he looked in the book. My hose is for a 1979 Firebird 350 non ac.
i went to napa and got a bottom hose for 69 roadrunner and had 2 cut it to fit my 440 in my 71 dart .it worked perfect for me and it was affordable to.
Take a couple of wire coat hangers and cut them and straighten them out. Now, center one on the water outlet on the intake and bend it so the other end is centered in the top radiator inlet. Take the other straightened coat hanger and do the same with the bottom. Now go to the parts store and ask to go back to the back and match your shapes up. Make sure to get the right diameter hoses.
