Got this 26 inch radiator AND shroud that I pulled from an 80 Cordoba I parted out. It wasn't correct as the mounting holes were way off, so I don't know what this came in originally. It definitely will fit something with a 70 and up small block based on the lower hose nipple. The top mounting hole is about 28 1/4 inches center to center and top to bottom about 8 & 1/2 inches. Seemed to be in good condition with no leaks. $75 for radiator and shroud plus the ride from 22657.
