What other radiators will fit in a Early A? Like one from a Volare or a Diplomat?
I have a 22 inch from a 68 Dart in my 65........went right in. For 65 and up the rad support has the proper opening for a 22 inch.
Depends on the years involved. With some swaps just redrilling the mounting holes is all you need. Other swaps require different hose(s) and/or adapting the trans cooler lines. Another area I've found a problem is the upper tank size/shape. Some have more hood clearence than others.
