Not sure, The guy I bought it from says he baked it on. It looks too silver to me and I was going to have it bead blasted. I was actually thinking of painting it 273 red.VERY nice intake! What did you use to finish it?
Plumbing store :wack: I need to shorten it otherwise its fine I guess. Does anyone make one?Is the bypass hose fitting the right size to match your water pump? I am having one made to match on my truck.
Magnum full of Coors:blob:Looks good Wally! What will you be bringing to Mopar Fest?
Looks great Wally! Keep the color as is, adds a nice pop to the engina bay! We discovered with dads car that if we put the LD4B on we would have to figger out where to mount the coil too. You could modify a coil bracket and have it mount under one of the rear carb bolts??
