Ralley Trim Ring for 14x5.5 rim
mderoy340
Melbourne FL
The trim rings I have for my 14x5.5 rims don't fit correctly. They measure 2 5/16" deep and are not hitting the inside portion of the wheel. I suspect they are correct for a 14x6 rim.
Does anyone have a good measurement for the depth for a 5.5 wide rim. Going to a car show/swap meet in Melbourne this weekend to see if I can find the right trim rings.
1st photo 2 5/16" depth.
2nd photo of trim ring not going in enough.
3rd photo correct fit that I want to get on my front rims. This pic is one of my rear tires (wheel vintiques 15x7 rim and trim ring).
Thanks for any info.
car-part-pic-wheels-001-480x640-jpg.1714784562
car-part-pic-wheels-002-640x480-jpg.1714784563
wheel-pics-001-640x480-jpg.1714784564
this broken link post was repaired by "view, copy, reply and paste URL in IMG tags" method. Took me 10 seconds. I was not OP, anyone can do it.
est
I'm reviving this thread because I'm having the same problem. I have factory 14x5.5" rims stamped with years 71 and 72. I don't know the vintage of the trim rings. In this picture you can see that the lip on the rim is less than 1/2" (as best I can measure, it's about 5/16"):
but the equivalent measurement on the trim ring is closer to 9/16":
Sure enough, when I press the ring in, it sticks out 1/4" from the rim on both the inside and outside diameters. If I'm looking at this right, the trim ring is made for a rim with a wider lip.
Replacement pictures needed because Dropbox shut down public links:
