No pictures unfortunately. I didn't have the wiring for the ralley dash. I had to figure out what wire went where, which I wouldn't recommend. I would find the ralley dash harness if you can. I didn't have a wiring diagram.
there are all of 3 wires to back out of the round main panel connecter. They move to the 3 pins on left printed circuit board of a rallye panel. Camparing the 2 panels side by side helps determine which 3 that went to what need to be relocated so they still goto same.
Just from memory , one is the left turn lamp wire.
