Ram Air 3 inch oval exhaust kit
Spintech also has them and a little cheaper too, was looking at these for my setup just 4", but decided to just run the straight pipes since its turbo.
Other than ground clearance, what's the advantage?
Is the cost worth the extra what.......1/2" clearance?
Would be cool to see 3.5 oval tailpipes to make it around stock tank .
Guess it would be worth it if you wanted to lower the car for handling purposes. But the cost for my set up it just isn't worth it for me.
