[SOLD] RARE! Factory Z-Bar, Bracket & Spacer for 67-69 Big Block A body 4 Speed Cars $100 plus shipping
gregpurcell
Greg Purcell
Near Savannah, GA
Ok, I'm lowering the price to $100 plus shipping.
This is an original Z bar, the special bracket and the spacer from a 67 383 4 speed Barracuda with a 10 1/2 inch bellhousing. ( I took it off myself)
I have one of the attaching bolts (standard replacement bolt can be bought at a hardware store) I also have 3 new nylon bushing shells from Year One. (you'll need one more-Brewers has them for $1.95 each) Located in Savannah, GA again price lowered to $100 plus the ride.
NOTE: Brewer's website indicates that this part will NOT work with TTI Headers.
If you prefer new, Brewer's gets $89.99 for the Z bar
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
$99.99 for the bracket and spacer
Or $229.00 for the entire kit:
Thanks for looking!
It uses the standard 67-76 A body ballstud and inner fender reinforcement bracket. If your car is currently (or was from the factory) a standard transmission vehicle. it will already be on the car. If you are converting from an automatic you will need to weld on the bracket.
I have the reinforcement bracket. The only ballstud I have is worn on the head but I will throw in both pieces if you need them.
Brewers has them also
http://www.brewersperformance.com/proddetail.php?prod=BS766F
