[SOLD] Rare Set of Stage II Heads for Big Block Max Wedge
wupracing
Lumberton North Carolina
Heads have been SOLD
Here is a Rare set of Stage II Heads casting # 2402286 These are the 4 bolt hole valve cover heads Max Wedge.They have Stainless Valves 2.14 x 1.88 with K-Motion 1000 Springs.The springs are set for a Roller cam 707 lift.
Where the head bolts go through the heads next to the push rods.It is thin where the bolts go through and the two middle head bolt hole have been welded on some.We have ran it this way for years but when we took them off the last time one of them broke out you can see in the picture.It can be fix but we are getting out of racing and no longer need these..
This is the Stage II heads that uses the Cross ram intake.It is a Rare Set of heads.
Other than the broke out head bolt hole they are ready to be bolted on.
Also have the Indy Intake for (440) block & Indy Roller Rockers and the Orig. Stage II Rocker Stands for these Heads.Will make a Package deal if buying the heads
Asking $700 for the heads.The Valves & Springs plus Machine work cost over half of the asking price.
I can send more pictures.
that is a rare set, and reasonable price. Do you have any pictures of the intake and exhaust ports? Maybe one with a valve removed, to see the pockets?
Here is some I took today of the ports.Did not want to make a trip to the Machine shop to take the valves out.
