I was wondering the proper way to install a ratchet shifter, trim out carpet around shifter? Install shifter over carpet? and is there an easier way other than using nuts and washers from underneath for quick shifter removal, And is it a good idea to use a rubber grommet to route the cable through the floor pan.
