mpaahana23
I'm getting a free 413 engine for free
is it worth to build
is parts hard to find ?
nice carMy parents new 1962 Chrysler New Yorker station wagon came standard with that 413 motor, never had a problem. Don't know about parts availability. From Wiki: The 413 RB had a 4.1875 in (106 mm) bore and was used from 1959-1965 in cars. During that period, it powered all Chrysler New Yorker and Imperial models, and was also available on the lesser Chryslers, as well as Dodge's Polara and Monaco, and the Plymouth Fury as an alternative to the 383-cubic-inch B series engine and/or the 318 Poly. With a compression ratio of 10:1, it developed 340 brake horsepower and 470 lb-ft of torque in 1X4-Bbl trim.
Many of the parts are interchangeable with the 426 wedge & 440.... (Except bore related....)
what about headers ?
I have a 66 Plymouth valiant
going be tight
thanks413 - 426 wedge - 440 all have the same stroke...
You can interchange cranks, oil pans, oil pumps and pick-ups, heads, intakes, exhaust manifolds/headers, timing chain, timing chain cover, water pump, valve covers between them... Like I said - everything but bore related parts... They all have 3.75" stroke and same deck height...
it might be darnBe careful it is not an industrial or motorhome engine. They have hermorphadite heads that you will not want to use.
it might be darn
IF it is the industrial engine, isn't the block the same as a standard engine?
Pistons are expensive.
Rest of the parts are standard big block, if the motor is out of a car.
wonder how far a guy can safely bore a 413 .???on the average? put a set of cnc`d alum. heads on it, a stroker crank, you have an over square stump puller.Thanks Bobby. I figured as much BUT you never know. With that said, I'd follow the Summit link for the new slugs and start in right away.
The best thing about a big block are really nice head/intake choices that work really well with the increased displacement over the small blocks.
