ValiantS
I can do some 'packaging' with these parts and other unlisted associated parts not listed depending on your needs. I'm about 25miles North of Detroit, Michigan 48316.
1)Roller cam LSM 4/7 swap NEW 278/290 @ 050 .490/.480 lobe 112 lsa (.730"ish lift with 1.5 rocker)$450
2)Roller cam Lunati NEW 276/284 @ 050 .460 lobe (.690"ish lift with 1.5 rocker)$275
3)Billet solid flat tappet ISKY '590' 320 adv 280 @ 050 matching NEW lifters and NEW iwis roller chain SOLD AS KIT ONLY $350
4)"B" engine '451' reciprocating kit: Good std 440 crank core/NEW BME 6.76 rods/4.375" JE pistons with pins (good used) $1200
5)1971 440 block partial fill std bore, good used ALLOY caps, bushed/indexed lifter bores $850 (needs finish machining)
