RC hobbiest? Parma's new RC body
zac_F71
Clitherall MN 56524
Parma just released a new Short Course Truck body - a 71 Demon it says 1/10th scale but it is 1/8th scale and has a 13" or so wheel base! I picked one up off eBay and some Purple paint for it.. found a cheapish 1/8 drift car I plan to mount it to and put some decent rubber so it can be a decent on road car.. They also make a 69 Olds Cutlass 442
http://www.rccaraction.com/blog/201...-for-short-course-parmapse-71-muscle-baja-sc/
Yes indeed - sadly the only downer about this body is the front wheel wells are flared very largely.. no biggie though it should still look great!
And POW! Got it basically done! I won't lie it was hard to start cutting up a brand new RC (hasn't been driven yet) LOL but it was worth it as it will look great I think once done..
I bought Tmaxx 14mm hubs to replace the 12mm Slash one's (funny car wheels use the same hub). I mounted up the front and rear wheels/tires and tossed the body on - the funny car tires are 13mm wider offset than the Slash tires SO I brain stormed for about an hour on how to narrow the rear - My Dad suggested to put it in the "sway bar mount" (I'm guessing that's what it is)
Sadly a lot of the mods are semi permanent - cutting of a few things - and such. I haven't run it yet and am going to try it with the XL5/12T only going up in pinion to a 24t it the setup proves good I may buy a Castle 3S setup for it and design up a scale functioning wheelie bar for it. Only modding to the front was cutting the coil springs 3 coils each rear shocks are stock just took the preload clips out. Let me know what you guys think?
On to the pics!
Here is how I narrowed it - drilled "sway bar mount" tab w/ 1/8" drill bit all the way through and made a divet in the other tab for the pin to lock into - - Had Tamiya TA05 turnbuckles and some Clod ball studs left over and they worked great for shorter upper links! You can see the outer part I cut off the lower arm - it also lowered it quite a bit which is a bonus! also moved the rear blocks forward as well a good 5mm I'd say..
Last one of the body mounted and the final ride height - going to add the Muscle Machines blower to the hood as well!
Did you ever finish the RC demon? post up some more pics if you did. Looks like an interesting build!
