Reading spark plugs, looking for feedback.
R68DartGT
Active Member
canada
91 octane gas. I was putting in octane booster but replaced plugs and stopped using the booster for about 4 tanks of fuel.
Looks like timing burn line is right. 3rd pic cylinder not running as well as the rest. Caramel color isn't bad but darker than typical. How was the engine run just before shutdown? Tyoically run hard, like drag race pass and shut off. The slow down and idle will change the coloring
It’s hard to tell with MMT on the plugs. One plug is getting oil. I’m going to assume it’s fat at idle with all the MMT on there.
What does the plug look like where the porcelain meets the shell?
Also you can skip the additives. At your compression ratio you just don’t need them. If the engine acts like it wants an octane booster there are better remedies than that.
