Realistic Expectations - 11 second Demon weekly driver
Big Block A body Tech
  1. xguard
    xguard Member
    13
    11
    May 23, 2017
    Louisiana
    Local Time:
    11:52 AM
    I went with the Eddy Torker or Torker II maybe it's called. Seemed like from dyno articles it was decent. Any experience with that one?
  2. PRH
    PRH Well-Known Member
    2,607
    3955
    Dec 14, 2018
    So. Burlington, Vt
    Local Time:
    12:52 PM
    The original Torker has very small runners.
    It makes good low/mid-range power but will definitely hold you back in terms of HP.
    The Torker II has better upper rpm power, but isn’t as strong as some of the more modern intakes...... and isn’t quite as good as the old SD.
    But, it’s good enough to run 11’s with no problems.
    • Like Like x 1
    • Agree Agree x 1
    • Carnut68
      Carnut68 New Member
      2
      9
      Sep 20, 2020
      W. Md.
      Local Time:
      12:52 PM
      I run the torker II. Stock stroke 440 EZ heads done by PRH. 1082 @ 125. 10.84 @126. A body.
      • Like Like x 7
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        39,060
        10619
        Jun 21, 2005
        New York, on a Island
        Local Time:
        12:52 PM
        Welcome aboard!
        • Like Like x 1
        • SuperStock426
          SuperStock426 FABO Gold Member FABO Gold Member
          264
          159
          May 20, 2020
          Fort Oglethorpe Georgia
          Local Time:
          12:52 PM
          We replaced a friend of mines Team G with a Victor 440 and it picked up 2 tenths. Not the first time I've seen this happen with Team Gs..I'm talking from experience at the drag strip. If you want to castrate a 440 stick a Team G on it, it'll hook in the mud then.
          • Like Like x 1
          • SuperStock426
            264
            159
            May 20, 2020
            Local Time:
            12:52 PM
            The Holley Street Dominator is a damn good intake for mild to mediocre 440.
            • Like Like x 1
            • 496 polara
              496 polara moparts id gch
              419
              156
              Feb 23, 2014
              North Carolina
              Local Time:
              12:52 PM
              Ran one on my 470 and again on my 496.Pulled hard on both setups.
            • SuperStock426
              264
              159
              May 20, 2020
              Local Time:
              12:52 PM
              My very first 440 I had many years ago had the old 509 purple shaft, 906 heads, 10.1 compression and the Holley Street Dominator. It's a real good working combination.
            • SuperStock426
              264
              159
              May 20, 2020
              Local Time:
              12:52 PM
              The Holley Street Dominator pulls up to 6500. Maintains good low end torque as well. Good little intake.
              • Agree Agree x 1
              • famous bob
                famous bob mopar misfit
                17,554
                7035
                Aug 14, 2011
                okla
                Local Time:
                11:52 AM
                Not entirely true , but this one aint stock--------------cant tell the diff between it and my victor . IMG_0435.JPG
                • Like Like x 1
                • 496 polara
                  419
                  156
                  Feb 23, 2014
                  North Carolina
                  Local Time:
                  12:52 PM
                  I remember an old magazine article dyno testing intakes and the Team G they had suffered from major core shift.
                • SuperStock426
                  264
                  159
                  May 20, 2020
                  Local Time:
                  12:52 PM
                • DrCharles
                  DrCharles Well-Known Member
                  947
                  695
                  Jun 7, 2012
                  West Plains, Mo.
                  Local Time:
                  11:52 AM
                • famous bob
                  17,554
                  7035
                  Aug 14, 2011
                  okla
                  Local Time:
                  11:52 AM
                  Not true on mine , wasnt much worse than the victor .
                  I gasket match everything to my cnc standard ports anyway.
                  the runner flow/spread between the runners is what is usaually wrong w/ the team G , the one I showed in the previous post now only has about 25 cfm scatter ,
                  which is way closer than a lot of ''so called great'' intakes , if you tested them . .
                • SuperStock426
                  264
                  159
                  May 20, 2020
                  Local Time:
                  12:52 PM
                  Read the 2 part article that Dr.Charles sent on Hot Rod testing several intakes plus the one I sent a link to. They're pretty good articles
                • famous bob
                  17,554
                  7035
                  Aug 14, 2011
                  okla
                  Local Time:
                  11:52 AM
                  I THINK THE ARTICLES ON HUGHS WEBSITE ARE PRETTY ACCURATE , COINCIDE WITH WHAT I`ve seen on a flowbench , before I reworked mine , after a whole bunch diff. . ,not interested any farther than that-------
                • SuperStock426
                  264
                  159
                  May 20, 2020
                  Local Time:
                  12:52 PM
                  Why did you have to rework it ?
