Rear axle adjuster on left side??
Transmission and Drivetrain Tech
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    6:39 PM
    My axel adjuster is on the left side. To my understanding this is wrong. The rear is a 71 duster 8 3/4 in my 65 barracuda. After fixing the reverse wheel hop issue i noticed a slight vibration at about 3000 rpm and up. The axels do have more end play than they should have almost .020. I know it should be about. 006. I am thinking who ever put the rear in the car goofed.
  2. 69 M-CODE CUDA
    69 M-CODE CUDA Well-Known Member
    68
    82
    Dec 4, 2017
    Fitchburg, WI
    Local Time:
    6:39 PM
    You're right. The factory service manual says the adjuster is on the passengers side. It's spec'd to have a (.007-.017") end play. Make sure it has the locking pawl to secure it's final position, also.
    • Agree Agree x 1
    • 69_340_GTS
      69_340_GTS Well-Known Member
      4,092
      1962
      Jul 11, 2014
      Torrington, CT
      Local Time:
      7:39 PM
      I wouldn't think it really matters which side it's on. Assuming all the parts are there and are functioning correctly it would still work, wouldn't it?
      • Agree Agree x 3
      • Like Like x 1
      • Disagree Disagree x 1
      • RustyRatRod
        RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
        64,385
        37338
        Jun 7, 2010
        Georgia
        Local Time:
        7:39 PM
        That is incorrect. Someone has assembled it wrong. While it "may" not matter, I am not sure of that, so if it was my car, as little work as it is, I would change it.
        • Like Like x 1
        • Agree Agree x 1
        • RustyRatRod
          64,385
          37338
          Jun 7, 2010
          Georgia
          Local Time:
          7:39 PM
          The reason the adjuster is put on the right side instead of the left is because the adjuster would not loosen up if somehow the lock tang was to break or be accidentally left off. The adjuster would tend to want to turn in the direction of axle rotation. If it was on the left side, that would be counter clockwise and it might loosen up without the tang in place. On the right side it would tend to want to turn clockwise which would tighten.
        • 69_340_GTS
          4,092
          1962
          Jul 11, 2014
          Torrington, CT
          Local Time:
          7:39 PM
          Too tight or too loose, they're both bad. That's why there is that tang/pawl. Leaving it off, or leaving it loose is just as bad as leaving the cotter pin out of the front wheel bearing nut(s). Either way, you'll lose a wheel eventually.
        • challenger57
          challenger57 cuda57
          207
          15
          Sep 21, 2007
          york, pa.
          Local Time:
          6:39 PM
          I thought my thoughts were correct. Who knows how long it has been that way. I have had the car 14 yrs and never had a reason to look until now. Thanks for the conformation and reasons.
        • RustyRatRod
          64,385
          37338
          Jun 7, 2010
          Georgia
          Local Time:
          7:39 PM
          I understand that, but if you HAD to have one or the other, which is it? Besides, just turning with axle rotation won't be enough to tighten to the point of damage, yet on the left side it could loosen up all the way. So one is definitely worse.
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          16,450
          4841
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          6:39 PM
          I have taken a few apart with the adjuster on the drivers side. They were cars that never had any work done to them, nii oh t even at the dealer. Who knows it could be somebody building them screwing around. Kim
          • Agree Agree x 1
          • pt70
            pt70 Well-Known Member
            403
            314
            Aug 23, 2019
            CT
            Local Time:
            7:39 PM
            I'd keep things as they are. For the adjuster to 'turn out' the tang/lock must break first and then the outer race of the axle bearing must spin in the housing. This would happen going forward, only.
          • famous bob
            famous bob mopar misfit
            17,504
            6976
            Aug 14, 2011
            okla
            Local Time:
            6:39 PM
            This ^^^^^^^^^^^^^^^^^^
            TH stock 66 belvedere 8 3/4 I had in the old hemi car ,came w/ it on the drivers side from the factory, was there until we went w/ the dana 60 , we ran more than .017 play too.
