Infiniti Dave
Member
I'm working on a rear axle swap with a "B" body 8 3/4 axle into a 79 Dodge Aspen RT. I have the correct lower spring mounts , but the shock configuration is different as the lower shock is a "Bolt/Bushing" arrangement instead of the original bottom" Stud/Nut" F Body. I'm thinking OE B Body shocks should work but I'm not sure about their length. Also see that the rear flexible brake hose is different. Not sure what model/year application should fit. Any information is appreciated.
