Rear Axle
Flyingbrick
Member
Hi Guys
Only had my mopar for a couple of years, so Im still learning :book:
I have a 69 valiant which still has it slant six rear axle, however I have dropped a 360 into it. Are all A body 83/4 axles the same width and will I need to change the rear half of the propshaft?
I think you will find all A body rearends are the same width. Regarding the driveshaft it will probably have to be shortened because the 8 3/4 center section (third member) is longer. Also there are two sizes of yokes small and large. All the A body rearends I have seen came with the small yoke. However Its possible you may find an a body housing that has a third member with the larger yoke for the u joint that will not work with your driveshaft even after shortening
