17remfan
- Joined
- Feb 5, 2009
- Messages
- 222
- Reaction score
- 0
Ill spell it out quickly and thanks in advance for any help. Went to adjust my front drum brakes on the 69 Dart today. They were both in need of a few turns "to tighten" and responded fine. From under the car looking at the star wheel , I used to brake spoon to rotate the star wheel from the top downward.
Now for the REAR brakes . I need to tighten the pads as they are not hitting the drums( 1 only slightly). I went in the same direction as the fronts ,rotating the star wheel downward and got NO adjustment responce from either side.
I am able to rotate the star wheel ok. Do I need to move something to the side first?? and am I going in the correct direction in the first place for the rears??
