Rear Gear Question
Did Chrysler make a 3.31 gear for the 8-3/4 rear? or did they just do the 3.23, 3.55, an 3.73?
thanks,
Eric
"Gear ratios available on the 8-3/4" axle through the years include: 2.76, 2.93, 3.23, 3.31, 3.55, 3.73, 3.91, 4.10, 4.56, 4.89, 5.17, 5.57. On OEM gear sets, the ratio is usually stamped on the ring gear edge. Ratio may be determined by the number of teeth on the ring gear divided by the number of teeth on the pinion gear or by counting the ratio of the number of turns of the pinion relative to one turn of the axle shaft."
from Google my friend
