Rear Main Seal leak
Mopar General Discussions
  1. SuperStock426
    SuperStock426 FABO Gold Member FABO Gold Member
    371
    250
    May 20, 2020
    Fort Oglethorpe Georgia
    Local Time:
    2:33 AM
    Fired up my 440 on Monday. Everything sounded good, good oil pressure, no over heating issues. Ran it for 20 minutes at 2000 rpm's to break in the cam. Then alas I look under the car and see a puddle of oil. Put it on the lift and wouldn't you know it, the rear main seal was leaking. When I built this engine I installed the "red" high performance rear main seal from Fel-Pro. Everything was done correctly except I didn't stagger the rear main seal. The engine was built in 2014 and fired it up this past Monday. Is it possible after sitting for nearly 7 years on an engine stand that the rear seal could have dried out? I ordered a new red seal along with a stock type rubber one to get the side seals as the red one doesn't come with side seals. I dropped the drag link and the oil pan, pulled out the main seal bridge and the rear main cap. Cleaned everything thoroughly and re- installed it with the stock type seal except this time I staggered it. Hopefully it'll seal up this time. Has anyone else had this issue?
  2. pishta
    pishta I know I'm right....
    19,640
    9003
    Oct 13, 2004
    Tustin, CA
    Local Time:
    11:33 PM
    always stagger. Just makes sense on these split rear main seals.
  3. SuperStock426
    371
    250
    May 20, 2020
    Local Time:
    2:33 AM
    If the one piece rear main seal had been available when I built this engine I'd of got one.
  4. inertia
    inertia Well-Known Member
    3,453
    726
    Feb 4, 2011
    Victoria B.C. Canada
    Local Time:
    11:33 PM
  5. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    19,545
    7953
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    2:33 AM
    Is this a BB? If so it may be one of two problems. Maybe the seal was installed backwards, or the rear main seal cap may have had the bottom of the bolt hole knocked out by using to long of bolts. Like this one pictured.
    • Thanks! Thanks! x 1
    • SuperStock426
      371
      250
      May 20, 2020
      Local Time:
      2:33 AM
      Yes. It's a 440. Seal was installed correctly. I double checked it . The seal bridge looked fine.
    • SGBARRACUDA
      19,545
      7953
      Dec 7, 2006
      Local Time:
      2:33 AM
      Remove the two pan bolts in that seal cap and use a ice pick or something like it and see if the bolt holes have a bottom.
    • SuperStock426
      371
      250
      May 20, 2020
      Local Time:
      2:33 AM
      I removed it today when I cleaned it up and reinstalled it with a new staggered seal. I closely inspected it when I cleaned it up and everything looked good. The oil pan is still off of the engine so I'll double check the bolt holes.
      • Agree Agree x 1
      • pishta
        19,640
        9003
        Oct 13, 2004
        Tustin, CA
        Local Time:
        11:33 PM
        One piece rear main seal...how the heck? I think its still unavailable because.....
        • Agree Agree x 1
        • Joey4speed
          Joey4speed FABO Gold Member FABO Gold Member
          1,288
          977
          Jul 17, 2018
          Jersey
          Local Time:
          2:33 AM
          I had the Viton rubber with the billet cap available from Mancini Racing, twice on my 383...
          Still leaks.
        • pishta
          19,640
          9003
          Oct 13, 2004
          Tustin, CA
          Local Time:
          11:33 PM
          • Agree Agree x 1
          • ch1ll
            ch1ll FABO Gold Member FABO Gold Member
            896
            337
            Jun 12, 2009
            Belgium,wi
            Local Time:
            1:33 AM
            Did you inspect the knurling on the crankshaft where the seal rides? If the knurling grooves are worn its always going to leak.
          • pishta
            19,640
            9003
            Oct 13, 2004
            Tustin, CA
            Local Time:
            11:33 PM
            and if its a reverse rotating boat motor crank, the wick lines are the wrong direction......Now that would be a WTF moment!
            • Agree Agree x 1
            • Bewy
              Bewy Well-Known Member
              408
              213
              Jan 1, 2021
              Australia
              Local Time:
              4:33 PM
              Is there a one piece rear main seal available for the 440?
            • oldkimmer
              oldkimmer FABO Gold Member FABO Gold Member
              18,847
              6198
              Nov 11, 2006
              Kindersley, Saskatchewan,
              Local Time:
              1:33 AM
              . There is something but I can’t really remember. I read about it on FBBO. About $75.00. Supposed to never leak. Kim
            • SGBARRACUDA
              19,545
              7953
              Dec 7, 2006
              Local Time:
              2:33 AM
              One piece with a flange is not possible.
            • famous bob
              famous bob mopar misfit
              19,315
              8430
              Aug 14, 2011
              okla
              Local Time:
              1:33 AM
              yes there is , about $75 or so , you have to split it w/ a razor blade to install it . but it will only have one seam in it , which u put up in the block around a 12 o`clock position ------
              My rear main seal housing was cast and drilled offset , I fitted it up to the block all cleaned up and w/ no side seals , just the cranl seal in it , it set off to one side . Bought an aftermarket billet one .
            • SGBARRACUDA
              19,545
              7953
              Dec 7, 2006
              Local Time:
              2:33 AM
              Well then like I said with a flange, it is impossible to install a ONE piece seal! If you have to cut it, it is not a one piece seal.
            • famous bob
              19,315
              8430
              Aug 14, 2011
              okla
              Local Time:
              1:33 AM
              SURE IT IS , ALL ONE PIECE , U DONT SEPARATE IT !----LOL
              I KINDA LIKE THE IDEA, BUT NOT $75 WORTH .
            • SGBARRACUDA
              19,545
              7953
              Dec 7, 2006
              Local Time:
              2:33 AM
              Ok.
            • oldkimmer
              18,847
              6198
              Nov 11, 2006
              Local Time:
              1:33 AM
              There is a write up on Fbbo about the installation. Kim
            • Joey4speed
              1,288
              977
              Jul 17, 2018
              Jersey
              Local Time:
              2:33 AM
              Didn't I hear of an egine builder that bored a recess in the rear cap assembly, then it was able to accept a 1 piece GM seal?
            • SGBARRACUDA
              19,545
              7953
              Dec 7, 2006
              Local Time:
              2:33 AM
              Look at your crank right behind your flywheel or flex plate, and tell me how you can adapt a Chubby or any other one piece seal?
              • Agree Agree x 3
              • SuperStock426
                371
                250
                May 20, 2020
                Local Time:
                2:33 AM
                Fastfish sells them.
              • SuperStock426
                371
                250
                May 20, 2020
                Local Time:
                2:33 AM
                It has a Ohio Crankshaft 4340 race crank in it.
