Does anyone know if the rear quater trim (that goes on top of the rear quater panels on dart convertibles) are the same as hard tops? if not, can you make them fit or are they too much different? thanks
IIRC the hardtop is somewhat longer than the ones for the convert. The hardtop trim runs right up to the rear window trim whereas the convert trim is shorter due to the little filler trim.
