Rear seat interchange 67 dart 2dr hd top
Dart fan
Monroe
Looking for help! What years do the rear seats interchange?
I would say that 67-69 dart rear seats frames would interchange
I will say that I have seen some seats that are more wire then formed frame.
This is an interesting topic.
On the surface, I'd think that any A body from 1967 would fit another 1967-76 model but....
There may have been changes. Maybe the 2 door models differ from 4 door cars? I thought that I was told that the 4 door cars had rounded corners on the lower cushion to provide more room to get into the back seat.
Only 67-76 2-door hardtop Dart or Scamp. 67-69 Barracuda coupe does not fit, nor do fastback or 2-door or 4-door sedan...
Yup, the 2 and 4 door cars are different for sure. And the 2 door hardtop being different from the 2 door post cars makes sense too since they used 4 door stuff. Barracudas were a whole different animal, and of course the Demon/Duster/Dart Sports are different too.
For the 2 door hardtops there are small changes over the years, the mounting tabs were changed at one point, I think that was around ‘70? Shouldn’t stop them from interchanging but you might have to fiddle with retention of the seat back at the bottom, would be covered by the seat though so not a visible issue.
Next would be when they went to retractable seat belts, the corners of the seats were relieved to make room for the retractable seatbelt mechanism. But 67-76 hardtops should all interchange as long as you’re not completely hung up on it being exactly correct. If you are, 67-69 would be the best bet, although I think the retractable seat belts didn’t start until late ‘72 or ‘73. My dates may not be perfect but they should be in the ballpark.
I've parted out several 72-76 A bodies and kept many seats....while not putting tags on any of them to help me remember what they actually came from.
Those should all be pretty much the same, the corners for the seat belt retractors would be the only possible difference in that year range and I think that would only apply to the ‘72’s. Not exactly sure when the retractable seat belts were added to the rear but it was around ‘73.
Thanks everyone for the great information I really appreciate it .
Dart fan
