[WANTED] rear seat pan
Lonnie Leach
Duster/ Valiant
Monroe Mi
Anyone around lower Michigan, Northern Ohio, That Has a Duster rear seat pan front section that welds to the rear foot wells
Do you want a rear floor pan section or a section from the piece that goes over the differential? Bigger pictures showing
where the rust is would help. Dodge and Plymouth are different in that area because of the longer wheelbase and the
separate foot wells in a Dart.
I Need the front of the section that goes over the Diff and under the foot well.. Its welded to the top part of foot well and is angled down to the Bottom of foot well
I have this stuff. Differential pan from a 76 Scamp. The diff pan is the same for Dodge and Plymouth. Foot wells are 76 Dart.
Maybe you could use these for repair sections. Plymouths don't use the foot wells as that is how the longer wheelbase is achieved
in a Dart.
The top one's front edge is what i need in a Plymouth the dart floor is More 90 degree and has them two big humps in it buy the shaft Tunnel my Duster has more a 45 with out humps
