rear spring recommendations
redfivexw
Hi,
I have a 70 duster, installing a v8 and an 8 1/4 rear to replace my slant and 7 1/4. I want to replace the rear springs, looking for advice on what you may have bought and maybe photos to show the stance. I like the slightly higher than stock look, but not too high. I would be interested in what you paid and where you got them as well. thanks!
If I could do it over again, I would call ESPO.
http://www.springsnthings.com/
I bought +1" xhd springs with an adjustable front shackle from mancini, which are going to be too stiff first off (150-160lbs.per"), coupled with not enough torque output from my 318 to make them work as desiged, puts me into considering a spring change already.
Had I called ESPO I could have gotten the feel (120-130lbs.per"), and look I wanted.
