Rear tail light assembly replacement
dartmansam
Member
Callifornia, MO
I am in the process of swapping out the tail light pigtails and will need to replace the bulb insert. Is there a specific way to remove these and or is there a part number to use to order the housing unit?
They made tons of 1971 to 73 darts with these tail lights. If yours are no good try posting a want add for a set in good shape. You might score a set for a good price and be done without the headaches
Dons auto parts has trailers full of good taillights also send them a PM.
