Rear Tire hitting front edge of wheel well
Plumcrazyfreak
MN
With my 70 Duster sitting still the rear tires are aprox 5/8" from the front edge of wheel well. If I drive it and make a tight turn the tire rubs on the front edge of well. I have a 8 3/4, Moser Axles, Comp Eng Rear adjustable shocks, New HD Leaf springs with rubber front bushings. Nothing is loose. Help.
Thanks
Got any swaybars ? Springs wont prevent body roll. You could add spacers in front of the forward spring hanger but you will need longer bolts too
The rear will move quite a bit on leaf spring cars. If you want to keep that tire you'll need to clearance the front of the wheel well.
Would some super Stock leafs with a metal front bushing work better ? The rear end will move forward that much ? This is happening at very slow speeds.
