rebuilding a slant 6
red_duster74
Hollywood, FL
hey im looking at rebuilding my slant 6 but i need some help in knowing what i need because i plan on putting a 4BBL carb on it.. any suggestions?
What kind of car, and what type of use? Daily driver (around town, or mostly interstate), street/strip, strip only? Fuel milage a concern, etc? Need more info.
daily driver and its a 1974 duster with the slant 6 225ci. fuel mileage is a concern but with an old car like this its less important than the beauty of the car and sound of the engine/power
The last Dart 225 I built I bored .060 over, 9 to 1 pistons,head shaved 0 .090,1.70/1.44 valves,460/276 cam,Offy intake w/ 390 Holley,Hooker headers,MP elect dist,MSD Ign,TCI 3200 conv,TCI reverse manual VB,8.75 rear w/ 3.90 gears !!At 70 mph I still got 15 mpg on the highway !!:cheers::cheers: Got my next /6 project sitting as I gather parts for another build !!:toothy10:
I did mine .030 over silv o lites, .020 off the block, .080 off the head w/ 1.70/1.44, iron 2 brl intake with holley 350 2brl , mp.460 lift w/268*dur cam, cross drilled std crank w/2.76 gears it got about 23mpg and around 20 mpg w/3.55
Something I built a looong time ago.
Bored 0.156" to give 247cid
Cam 311adv dur,104deg overlap,0.495" valve lift
Head shaved down 0.125",big porting,318 valves
Headers
Triple 45DCOE 2 barrel sidedraft weber carbs.
Few other minor bits'n'pieces.
We won't talk about mpg though.:shaking:
Up the compression and give it plenty of breathing room by milling the head, don't port, a mild cam, a 2bbl is the most efficient carb, but 4bbls are a little more fun.
Headers
Now that's what eye candy is all about! :-D :-D :-D
A 4-barrel will give you more top-end speed, but a 2-barrel can be better off the line. Also depends on CFM and jetting, etc.
venturi size is gonna make the diff, technically a 390 4 brl has smaller barrels all around, smaller venturi=faster air=better mix=more response/power till the engine can whip it up by itself.
so as long as the secondaries aren't opening too soon, the 4brl is gonna have the same or most likely better off the line.
you can tune around this and get both real close in response/performance, but in the end the 4brl has 40cfm more flowing through it.
the build will make the difference, some street performance builds won't eat all a 350 holley can give, it becomes this almost slowing down with more pedal and speeding up as you let out of it......
one thing that will also cause this is not opening the 2brl flange up to the matching bore size of the 2 brl carb....it just drops out and go's slower from lack of speed even at 3k rpm. the intake becomes the cork.
Like it was said, 4bbl gives you more of a top end, but 2bbl gives you a little jump and better fuel economy that the four pack, just take your time on finding some gears for the rear end and you can get a decent toy with great fuel economy.
:wink:
I know what I'm talking about...
never had to do 1/8 mile calculations but is that about a 19.** 1/4 mile??
Couldn't tell you,all I had was the 1/8 in Immokalee Regional Raceway !!:dontknow: But I didn't build it to be the fastest,I built it to be DIFFERENT !!! And the numerous and varied comments made it all worth while !!:cheers::cheers::cheers::cheers::cheers:
i know i know as your fellow slanter! i was just thinking that my stocker went 18.30's in the 1/4...
not stock anymore!
One of my cars has a stock slant/904 with a 500cfm edelbrock 4bbl and headers.
Goes well and returns good mpg.Abt 21mpg at our 62mph open road limit.Feels like high 17 - low 18sec 1/4.Haven't run it yet though but I've been racing for 35yrs so you get a feel.
Used to have a holley 600vac on it which was abt the same.
Here's an 1/8 to 1/4 conversion chart for you.
So that 9.89 is around a 15.45 quarter in a perfect world which is a pretty stout slant!!!
i awlays just thought it doubled haha... thx for the chart!
so you think a holly 600vac would be a good carb for a street slant 6
