swing69
fightin' socialism
I'll get more info....the this engine has been in my garage for a couple of years, it was just fogged and wrapped and needs a home. The project car it was built for is gone.
1972 (I think) 360 (I'll check the numbers and update the ad). There was ~ 500 miles on the bottom end when I bought just the short block. Main bearings were perfect. So I left it alone. Windage tray. new Summit 6901 cam kit installed with lifters. new cam bearings installed. new timing set with mopar chain tensioner. new Milodon A body 5 qt. oil pan. Edelbrock Performer RPM (temp install). Professionally rebuilt heads (J I think - small valve). Engine fogged and wrapped. comes with the balance of the gasket kit to complete it. Painted mopar red. Engine was built to perform a little better than stock (better cam and intake). No CCing or head porting was done. $1200.
Also available: 360 to neutral bal. TC SFI flexplate. new...but NOT in date. $50 will NOT sell before engine goes....
Locate in central NJ 08852 near 8a of NJTPK. Pick up only. no shipping.
PM if interested. thanks Mike
