dennday67
I recently rebuilt a holley 1945 from a 70's dart 225 /6 and it went on my 1968 /6 EGR valve and vac adv hooked up to the right ports all others are cap. The rockers are adjusted to .011 in and .021 exh at operating temp while running. The timing is set at 2 deg BTDC (the ballencer tdc marks line up right) but I havnt checked what it is at total timing or with the vac adv (where should they be at idle and does anyone have a writen proceedure on setting that up). The ing is HEI setup just like how Dan Stern shows it in his pics. Im currently running NGK GR4 plugs gapped at .035 with a brand new dizzy. Intake and exhaust gasket has been changed by the book and cant find any vac leaks. When I give the carb a pump to set the choke I get a good strong gas pump charge. when cranking it feels like the timing is off but once its running at operating temp its very crisp and smooth.
