[SOLD] Rebuilt hot street 318
PNWsasquatch
Active Member
Vancouver WA
Rating - 0%
0   0   0
318 was rebuilt bottom to top about 4 years ago but still has very low miles. Drive to work a couple times and to a few cruises a year. Maybe 1500-2000 miles. stock bore and stroke, cast pistons and crank. hand ported 302 swirl port heads running 9.2:1 compression. Billet hydraulic roller cam done by Oregon Cam 270/277 int/exh 492/501 lift 110/106 lobe separation. Has Edelbrock Performer aluminum intake, a professionally modified 450 Holley carb and custom advance electronic distributor, MSD coil Taylor ThunderVolt 8.2 wires. M/T aluminum valve covers and A-body oil pan. Have a video of it running before I took it out of the car last weekend. Engine has instant throttle response at any rpm and carries good up to about 5600 rpm and cruises at 2200 rpm like a modern car. Many people have thought I had a 340 in the car by how it sounds and runs. Only reason I'm selling is I'm building a stroker engine for the car and have nothing else to put this 318 into. Only needs pulleys, engine mounts, air cleaner and exhaust to run. I didn't even move the distributor when I pulled from the car so no tuning needed. Can deliver for a fee within a reasonable distance of Vancouver WA. Will not ship $3500
