Kevinmatt
Member
I had my slant 6 form my 67 dart rebuilt . It's running a little warm and might be over heating . After running the slant 6 in idle for about 5 minutes the temperature reads 200°-210° degrees . I had original radiator cleaned and Roded out. So it's flows a lot better then before. But still my slant 6 reads 200°-210° degrees , I read that timing can cause overheating.
I need advice and help to find a solution!
