Redi-Rad
dmoore
NO IT'S NOT RESTORED
Eastern Shore of Virginia
This is a very nice device for playing most any portable device in your classic car without cutting up your dash in the process....I purchased this last summer for the Duster,,,it is overly simple to install...I just layed it in behind the lower dash trough by the stock radio, unplugged the original antennae lead & plugged it into the redi -rad, then plugged the redi-rad antennae lead into the radio, find a switched hot & ground at the fuse block & your done! No drilling,no wire cutting & it is completely hidden! All you have is the black lead coming down from under the dash to connect to your portable device....go to www.rediscoverradio.com for more info & you tube video....
I paid $129.00 + usps s/h.....I will take $75.00 shipped anywhere in U.S.A.
