1967Valiant
Active Member
Hello everyone been awhile since I posted and the Valiant is coming along nice, but not as fast as I would like. I am in middle of building fuse and relay box and have a question. The trip side of relay the ground and Positive that activate the relay the current is way small in amps, right? so I can trip the relay with 22gauge wires in the fuse panel since they draw little to no amps from positive or ground to trip the relay active. Is this correct? Also the only thing that size of wire will be used for is to trip a Relay. I attached a PDF photo for any input you might have.:happy1:
[img=http://img594.imageshack.us/img594/8192/img0045ac.th.jpg]
[img=http://img43.imageshack.us/img43/5785/img0046vj.th.jpg]
