Remote Starter Hookup???
blackace
The KING of flats
New Joisey
I picked up a Actron remote starter and tried hooking up but couldn't figure it out for the life of me. Anyone know how to hook one up? I followed the instruction but it didn't work. Obvisouly I am not doing it right.
I was setting up with a conventional iginition system / electronic system with separate coil.
It states to Disconnect the primary wire from the BAT (battery) terminal of the iginition coil. Remove the high tension lead from the center of the distributor and ground it.
I tired this but didn't work.
http://www.actron.com/product_detail.php?pid=16169
If your doing it on your Swinger (or any other Mopar) you don't need to unhook anything. You just hook it up to the starter relay. Just look where the starter wires are hooked up on the starter relay and hook one of the remote starter wires on one and the other wire on the other.
I guess they tell you to disconnect the coil wire so the engine don't start for saftey reasons.
Now that I guess you have it turning over, and you do want to start it, make sure the key is in the "On" position...for obvious reasons...:)
