earthmover
in the tire smoke
this is the front of my motor and im looking for some ideas as to running a remote water pump...I have researched some of the ways and looked at some of the stuff that's for sell...I just cant se myself paying 2/300.00 for a set of blocks that fit the opening and then buying an fitting...hat add another 1/150.00 to the cost..now most will ask why I want to run a remote pump...so here we
I have a aluminum water pump housing and some spacers to mount on this motor with a electric pump , but it moves my stuff out from where I would like it to be because I also will be running a aluminum radiator and electric fan to help with what cooling I will need..this motor is filled to the water pump holes and will be on alky.....id like to have a clean and simple looking set up...if the spacers was thinker I would just tap them and add an fittings but they are only about 1/4 thick and I don't really see them being thick enough..may looking in to buying the tools to tap in to the block and through the motor plate...not sure it it will be ok since the plate is taking the load of the motor...anybody got any ideas or pics I can see....also I know most will say im over thinking this but im just trying to plan for the best set up and for the next motor that will be in here..also I will be running a belt drive fuel pump for the toilet set up on this motor and maybe a vacuum pump on the next motor.....so any ideas would be great.....and I know some will say stop being cheap and buy the blocks but its not me being cheap but 2 little blocks no an fitting for 2/300.00 no way just cant see that...mopar stuff is just crazy.. :wack: I may just have to run a electric pump and move things back a little more.. but in front of the radiator is going to be a fuel cell for the alky and maybe 1 for the nos depending on how much of a hit I run..:-D
