markfh
It's been a long time since I tried removing heads while the engine is still in the car so please refresh my memory. What's the best way to do this without damaging anything?
Thanks
Thanks
Two more tips; 1) if you drain the block,both sides, you don't get near the amount of coolant into the cylinders.
Instead of prying in the coolant ports, you can pry underneath, going across the chinawall. Or whatever works for you.
I have some nice big ones that cover both outside & under the hood.
Drain coolent, while coolent is draining, remove dist cap and wires, then remove carb. next pull battery cable, positive. disconect wiring to alt and temp sending. Move wiring out of the way. Remove valve covers. remove alt and brackets. remove top rad hose, and bypass hose. remove heater hose from engine side. move heater hoses out of way. Remove intake. remove rocker shaft from both sides. remove push rods. If you are going to reuse any of the valve train parts, mark them to go back in the same place. remove exhaust manifolds. On the drivers side you wont be able to remove manifold, just remove bolts and lay it out of the way. might have to move it a few times to get to all the head bolts. Removing manifods is the tough part. Remove head bolts and then pull heads. You are going to get lots of coolent flowing when you pull heads. Normal. If car has AC, Im not versed on that, need others advice. Good luck. :burnout:MT
Metal to metal? Strange. :burnout:MTOn my 1970 Duster 340, there was no exhaust manifild gasket on the passenger side. The driver's side had the heat shield/ gasket.
Okay finally got back to this. So, I went ahead and tested compression on each cylinder to thinking that maybe I don't have to change the gaskets. Each cylinder tested out at 170 - 175 PSI. I take it that is where they are supposed to be and indicates no leaks requiring replacement. So my next question is would you go ahead and replace the gaskets?
At this point the only oil leaks I have been able to verify was the front and rear of the intake and the valve covers.
So you were thinking head gaskets for an oil leak? Or did I miss something?
If you have a leak, I would start with the valve cover gaskets.
