Removing A -Body Headrest
COdartman
Arizona
Anybody have some tricks to removing a headrest out of my 70 Dart Swinger bench seat. I removed the passenger side pretty easily but the drivers side is fighting back:banghead: Thanks for any advice!
Dave,
I had thought of using something down along the shaft to release the clips. Thanks for the tip!
Dave,
One of mine was really stubborn!! I squirted some lube down the shaft to hopefully lubricate the spring clip down near the bottom of the shaft. Then I worked it up and down to help get the lube all the way down. I ended up using a 2 X 4 basically slamming the headrest on the bottom side. I also built (stacked some blocks) on the back seat so I could use a 2 X 4 as a lever to push the headrest off. I finally got it off but it was tough.
treblig
Thanks Treblig! I will give the 2x4 and lube method a try to see it it will finally release. I guess back in 1970 this seemed like a good design, LOL...
Dave,
Thanks Treblig for the tip! I used a couple of blocks of wood and was able to persuade the headrest out of its 44 yr old home without any additional cuss words LOL....
Dave,
Just want to help anyone out by telling how I removed my bench seat headrests out of my 1970 Duster 340. These headrests have one long (RH) and one short (LH) chrome post.
Raise the headrest all the way up. Get a spray can of Kel's Heavy Duty Pure Industrial Grade Silicone (or equivalent) and install the straw tube. Now, insert the tube 1-2 inches down the backside of the right-hand post aiming straight down. The retainer latch inside the seat is on the RH post of both the driver's and passenger's headrest. Give it 2-3 squirts of spray. Be super careful NOT to get silicone on any vinyl, it MAY discolor certain types. Now, wrap the headrest pad with a couple layers of foam and secure with 2 or 3 bands of masking tape (to minimize the chance of damage). Push headrest down a notch and grab each post just below the pad (NOT the headrest pad itself) with your hands and quickly go upwards. One or two attempts should have the headrest out of the seat. It's simple, easy, fast, and it worked for me without any damage.
