stoke
Any tips on how to remove the heavy clutch pedal spring before I hurt myself? Thanks
I will try the washer thing. Thanks, the problem I am having is with a diaphragm type pressure plate not letting the pedal return, so if this doesn't
work I think I will put in a 3 finger type plate and try that.
