Removing heater blower box/ac unit help.
74RR
I;m going to remove the heater box and under dash ac unit in my 74 Scamp.
How do I go about doing this? Thanks.
some times it is worth the time to remove the front seats. that way you are not upside down and contorsionizing your back . trust me. it is worth the time and you might even be able to go back to work the next day without your chiropractor following you.
You should drain some antifreeze/water before attempting heater hose removal.Saves a mess.Removing the seats is good advise too.Start wrenchin !:iconbigg:
A manual comes in handy for stuff like this. Even if it is just a Haynes one. Service manual would be better though if you can find one.
