Removing rear interior panels from a 69 Barracuda
Rocket
U.S.A.
I am in the process of restoring my interior panels on my 69 Barracuda Fastback. All the seats and door panels are currently off. I am now trying to remove the metal panels that wrap around the sides and rear window. I have removed all the screws and the rear most panel has come off. The remaining pieced do not want to come off. They appreared clipped in and I am concerned about bending the panels.
Any tips or tools needed to remove these parts?
there are screws under the stainless trim strip that have to come out.
OK thanks. Is the strip itself easy to get back on?
It is held on with wire clips. Just be careful prying them up as you can bend the trim stip easily. To reinstall I just used a 6" piece of wood and a light hammer to tap them back in. The wood spread out the blow so the trim did not get damaged.
theres also a screw on one or both ends of the trim to remove.
It goes back on pretty easy, just be gentle and patient.
