blackace
The KING of flats
When I did a compression check on my motor I had to pull the header loose on the drivers side and stripped the very first thread on the #1 cylinder for the header. This is the one that runs in the water passage.
I was looking at a couple books that I have and they show how to repair the thread by inserting a coil type thread after drilling it out. Both books are atleast 20 years old.
Is this still how it's done? Anyone know where I can get this? I am assuming since I have to drill the thread out I would have to remove the head so the metal shavings don't get into the coolant, correct? If I drilled and tapped it I would have to go the next size up? Any one have any suggestions on how to repair this?
THANKS!
THANKS!
