Replace front end
zakimodo
Berthoud Colorado
the front frame assembly of my 74 duster is rusted and looks to be bent how do i fix it or do i scrap it?
Is it the K-frame that holds the engine? If so, scape it for a replacement.
If it is the frame rails to the body, rot dependent, go here for some help.
http://www.autorust.com/
well as you can see i never got those pictures. its hard to se unless your under the car any way. the k member is ok, its the driver side frame rail that looks bent.
