gdizzle
66 dart. Well fun time replacing the steering gear (power).
also rebuilt the little coupler.
So before, I had real sloppy steering, lots of play, wandered to the right pretty bad if I didnt hold it straight (which meant turning a little to the Left). But it was real loose and easy to steer. I could literally make a big turn wheel all the way over, then throw it back to center with a flick on the wrist.
New steering gear in, and wow now firm feel. If I can get the steering straight, it will not wander with hands off wheel. nice. The thing is there is now a bit of play, from when the steering wheel turns to when the steering gear engages. I can even feel the gear engage if I turn wheel slightly back n forth. Is there some way to tighten the amount of play in the wheel? so instead of having2 inches of play, maybe just have 1?
the feel is great. but that little bit of play has me moving steering wheel back n forth , in little baby moves to try to get it centered so it drives straight. once I get it centered it will drive hands free straight for miles.
In the box there is a little instructions that mentions 2 screws that seem to control the centerness. Then there is also the one big bolt thingy that can be adjusted. It says it is all pre-adjusted to factory specs.
