Hey Guys, I am replacing valve stem seals on my Duster with a 360ci. My problem is i have two different sizes and am not sure which are the Intake and which are the exhaust! Ones a bigger seal then the other. I should not have this problem because i would replace the seal with the size that is on it. My problem is some jack hole pulled them all apart then left them that way. so here i am putting my heads back together and dont know which size seal goes to which set of valve stems. You would not believe how hard it is to find this answer! any thoughts? Thanks in advance
