Resto Cluster Gauges Inoperable!
Mopar General Discussions
  1. QuickDart360
    QuickDart360 Well-Known Member
    1,177
    425
    Apr 5, 2014
    San Antonio
    Local Time:
    12:03 AM
    I removed my old but functional cluster. However, speedo not working just odometer. So looked for new speedo and is about 340 to 370 bucks! So ran across a restored cluster from Mr heaterbox out of Canada. Cluster comes refurbished with new circuit board, voltage limiter and restored and calibrated gauges. Install it and only speedo works! What can be wrong if all is renewed!?
  2. QuickDart360
    1,177
    425
    Apr 5, 2014
    San Antonio
    Local Time:
    12:03 AM
    Please folks shed me some light. May just use speedo with old cluster that was working. But really want to take advantage of new unit.
  3. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    61,996
    34202
    Jun 7, 2010
    Georgia
    Local Time:
    1:03 AM
    Is it properly grounded?
    • Agree Agree x 1
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      5,665
      2664
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      1:03 AM
      That is a huge opened ended question, sorry! Perhaps knowing all the issues you faced prior would be a good start before finding the need to replace it all.
    • QuickDart360
      1,177
      425
      Apr 5, 2014
      San Antonio
      Local Time:
      12:03 AM
      Ground is the 3 lower screws to dash? Or is there another ground somwhere? Installed like old cluster was and old one works good.
    • QuickDart360
      1,177
      425
      Apr 5, 2014
      San Antonio
      Local Time:
      12:03 AM
      Well before only faulty item was speedo which is 100% mechanical. My old cluster and guages were working just fine. This new cluster is dead @ the gauges. Not one is working! So I'm stumped.:(
    • 1969383S
      5,665
      2664
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      1:03 AM
      Normal ground is though the connection to the metal dash. Augmented ground sometimes is needed. why? A new shiny dash?
      • Thanks! Thanks! x 1
      • QuickDart360
        1,177
        425
        Apr 5, 2014
        San Antonio
        Local Time:
        12:03 AM
        Good you mention new shiny cluster! Old cluster I had sanded the tabs to dash and dash too. New did not. Also wonder if new style circuit board (green color now) is a good part or not so great?
      • RustyRatRod
        61,996
        34202
        Jun 7, 2010
        Georgia
        Local Time:
        1:03 AM
        Not a "very good" ground. I would run like a 8ga from the metal cluster frame to a good ground on the dash somewhere.
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        4,642
        2832
        Jul 16, 2017
        Northern Colorado
        Local Time:
        11:03 PM
        To test you could use an alligator clip a go from referbed dash to clean bare metal body part.
        Have you contacted the reman co?
        You can also bench test the cluster.
      • RustyRatRod
        61,996
        34202
        Jun 7, 2010
        Georgia
        Local Time:
        1:03 AM
        I guess just give up on it and throw it away. Damn man. A ground wire takes ten minutes to run. Ten minutes. If it doesn't work then, you got a problem.
        • Agree Agree x 1
        • 1969383S
          5,665
          2664
          Jan 8, 2012
          Cumming, GA.
          Local Time:
          1:03 AM
          The circuit board color is not an issue for you.
          Take a deep breath and get out the meter!
          • Agree Agree x 1
          • Dana67Dart
            4,642
            2832
            Jul 16, 2017
            Northern Colorado
            Local Time:
            11:03 PM
            How about some photos
          • beanhead
            beanhead Well-Known Member
            125
            151
            May 21, 2017
            wackyfornia
            Local Time:
            10:03 PM
            Seeing as how the speedo-meter is mechanical and is all that works, for sure indicates an electrical problem. Yes verify you have a good ground. Do the cluster lights work? The gauges themselves ground through their respective sending units. Did they 'forget' to plug the limiter in?
            This is from a Charger, but I think most of our old dogs had this setup--the part in front of the right arrow needs to be firmly pressed into slots on the board. The cylindrical one on the left just gets strapped down as shown: charger gauge cluster.jpg
            You might check the pins and sockets for the main connector plug too, sometimes they get loose or break off when you plug/unplug it.
            Rusty: "Hey guys, howdya like the Hemi in my new avatar?"
            The guys: "What Hemi?!" :p
            • Like Like x 1
            • RedFish
              RedFish Well-Known Member
              24,292
              2881
              Sep 5, 2007
              Local Time:
              12:03 AM
              How about a single candle light from you. what the heck you working on? Pictures of both removed and replacement would help. Some panels had 2 switched hot wires, a blue with white tracer (served limiter only) and a black. In later models the blue with white was deleted, black served all. So circuit boards need to be identical in circuitry. Ink color varies with mfgr. and is not a factor.
            • QuickDart360
              1,177
              425
              Apr 5, 2014
              San Antonio
              Local Time:
              12:03 AM
              1974 dodge dart sport 360.
            • RedFish
              24,292
              2881
              Sep 5, 2007
              Local Time:
              12:03 AM
              OK, I think oil warning lamp, park rake lamp, and limiter are all on the same 12 volt switched supply. Without wiring diagrams I can't say is this supply fused or not.
              Gauges wouldn't be tested or calibrated mounted in the housing. The new replacement limiter probably was never tested either. A new reproduction circuit board and limiter should work but... maybe not.
              If those 2 warning lamps work you do have 12 volts going to the limiter. If illumination, turn indicator, and hi beam bulbs work, you have chassis ground. Fault would have to be right at the limiter, the limiter itself or those springy female clips that are supposed to link its male terminals to the circuit board. i know some of these new boards have shorter pins for harness connectors. I don't know about the quality of their female terminals under the limiter.
              • QuickDart360
                1,177
                425
                Apr 5, 2014
                San Antonio
                Local Time:
                12:03 AM
                Will make some time to have a look.
