Rev Control Question
gold68dart
Poconos, PA
Sorry for the ignorance since ignition systems is not one of my strong points! I am currently running a electronic mopar chrome ECU and would like to know if/how I can install a rev limiter with my existing ignition system? I read the article in Mopar Muscle about the Rev-n-nator which sounded like a good setup since its really a plug n play. Not after big hp gains, just want to protect my motor on hard shifts. Are there any fairly "easy" options other than the Rev-n-nator? Thanks!!
Sure. There are separate limiters, as well as some tachs with built in limiters. These generally hook up to the coil NEG terminal. These types cannot be used on MSD or other CD type ignition, except by following the destructions of the specific ignition.
Your Mopar system works with the coil NEG.
